rear wheel bearing?
  LCR 225
hi i have bought a new rear wheel bearing for my 2003 clio 172 cup, an i have removed the rear hub to get to old bearing pressed out an the new one pressed in. the problem is i gave the hub to one of my work colleges an they have take it it to a garage an they have told them that it is all one part an the bearing is build in! i don't belive this 100% can any of you tell me if this is ture or not?
  172/1.2/E30
Rear bearing is pressed into the brake disc. It's exchangable but often easier/cheaper to get new rear discs with bearings already fitted.
  LCR 225
thanks that what i thought! because why would there be a clip there to hold the bearing in if its built in!
