Rear wheel bearings on a 172 part numbers plz
  Iceberg Ph1
Couldn't tell you the part numbers mate, but if your after a new set its worth perhaps changing the entire disc also, seeing as 99% of them come with the bearing already pressed into them, buying the bearings separate then having the old ones pressed out and the new ones pressed in by a garage would probably cost around the same as a set of genuine Renault discs and bearings and fitting yourself is a piece of cake!
Worth a thought.. if not what your after someone will give you the info for what you need soon no doubt
Edit: Links From K-Tec:
Discs - http://www.k-tecracing.com/show_product.asp?id=2761
Bearings - http://www.k-tecracing.com/show_product.asp?id=2318
Have a look on their site, they have a few brake packages on there..
  02' PH1 172
just spoke to the renault dealer here and they say that the discs do not come with the bearing pressed in :(
  Iceberg Ph1
Check the link above mate.. Bit odd as I would assume they did seeing as K-tec sell them already fitted, although this could be something they do themselves before sending them out
  02' PH1 172
problem is that I am in south afica now and ordering from k-tec costs a fortune for shipping and customs, otherwise i would have done it.
got a track day on saturday and need to have them replaced by then :(
  Iceberg Ph1
Eeek yeah I would assume that would mate.. Didn't realise you lived over seas! (seeing as London is in your location bar :rasp:)
Hopefully someone gets back to you with the numbers you need mate
  02' PH1 172
Drop me a pm and i will give the exact price and time.
man it is a good price, but my problem is that I need it by saturady as i have a track day. which I am pretty damn sure is impossible to make :)
good to know for the future tho, will be back in london next month :)
  Various
It can be there for Saturday but it would cost a fair bit. :)
Sorry mate
