Rear wheel bearings
  225 Cup & Williams
Where is the cheapest place to get rear wheel bearing? not really up for changing the discs as they are in ok condition i've had a search but i couldnt find much.
DrR
  VW Golf GTD
Reanult £100 for new discs with bearings pressed in, no easier cheaper option IMO.
  225 Cup & Williams
Yeah i had to do that with my williams they were pretty screwed though. Seems a bit pointless replacing the discs when they have plenty life left in them, Am i right in thinking the 172 rears have abs rings?
DrR
  VW Golf GTD
Unless you can take the old bearing out, buy a bearing, then have it pressed in (bear in mind you can't use the car while doing this) for less than that go for it, but i can't so buying new discs would be the best option for myself.
Yeah they have ABS ring, they come with them if bought from Renault.
Greeny.
  440i + 182
You can get the bearings fairly cheap from GSF/Eurocarparts etc, I had mine changed on my old old discs then bought Renault items when required.
  182cup & 172 racecar
I would only use genuine bearings and you will find that they only cost a fraction more with discs and it make life so much easier.
  225 Cup & Williams
Yeah that is what i am going to do, Seen genuine renault discs and pads with bearings and the ABS rings on ebay for £117.50. Good price?
  225 Cup & Williams
Cool i will have a look in the trader's section. Those one's i seen on ebay are from renault wolverhampton
