.Griff. said:Ok... Not sure why you mentioned a hardware firewall then but nevermind..
Adams_16v said:most likely be firewall problem or ports needed forwarding mate!
Roy Munson said:With my software firewall off, he was able to ping me, so that kinda estebalished (in my mind) that the two machines could technically see each other.
.Griff. said:Bear in mind there's a huge difference in 2 things being able to "see" each other and "interacting" with each other.
The only reason why the connection is failing is because something is blocking that connection. You say you have your firewall turned off, have you ensured Windows firewall is also turned off too?
Adams_16v said:u need to setup port forwarding for that, so it forwards the local LAN port to your WAN address!
