Remote locking conked out
My lad has a 1.2 Dynamique on an 03 plate with all the bells and whistles on it. The remote key locking/unlocking failed and he thought it was the battery. New one bought, same result. red LED is flashing on the key so is presumed working but nowhere can I find any reference to a receiver for it on the car, which must be the next suspect part. Can't find a reference to it in any part of the cars electric ciruits layout or physical reference elsewhere.
Anyone know where it's located so it can be checked?
  White Sti Hatch
Go in in the car and hold the Lock/Unlock button on the dash for a few seconds you should hear a beep press the fob and it should lock unlock the doors after that.....If that fails try disconnecting the batter for a half hour and reconnecting it and then try the fob
Tried the hold button down method last night. Didn't get a beep, so either it's a brain problem or a hard fault. Haven't tried the battery off yet as he has to use it to get to work.
  BMW F31
i hit a pot hole recently and badly damaged my alloy, another effect from this is that my RCL is now intermittent, when i shut my glove box it causes it sometimes to stop working, slam the glove box again and the RCL works fine.
i'm taking my dash top off at the weekend and checking the cables, i can report back if you like. :)
  Renaul clio 1.2 16v
My central locking stopped working onone side of my car. I too kthe door panel of and i had a wire that had snapped. that might be the problem
