i usually get a centre punch and hit the middel of the gold torx bolts which hold the disk on,
that then loosens them and if that still doesn't come off then hit the bolts with a centre punch on the outside then you can hit them off? hope that helps
Hit the dics from the back, when turning it, if you hit it in the same position say 12 o'clock, 3o'clock, 6 o'clock and 9 o'clock. given time it will come off.
