Remover Acoustic Valve, Not Sure :S
Car  182, 6r GTi
iv removed the acoustic valve on my 182. blocked the hose with a skrew and pluged it back in its louder on aceleration but on de aceleration the whold car vibrates ??? is this normal because it feels horid and if thats the case ill put it back in
thanks steve
thanks steve
I didn't notice any difference what so ever removing mine weather it be volume or the car vibrating.
It's only a valve, there's no reason removing it from the air Intake system would make the car vibrate
to put another cold feed into the airbox. the strange thing is that the valve only opens and closes when the engine is under load. not when its parked up being revved.
i thought about removing mine at one point, after using the search and finding a few threads on it it seems that its not worth bothering with and makes little or no difference.
Not had any negative effects from taking mine off, only a touch louder but saves a ton if weight!! Lol
Remove the valve, bag the connector to save water getting in and plug the vacum pipe at the inlet mani
