its easy justin, from one of the edges of the window, where it starts. peel it off, go slowly other it will break up in bits. do it slow to remove it all in one piece, then once removed, clean your window with that adhesive s**t from halfords.
i had to do them before. used a blade to get it started and then you can just peel them all back. use some whitespirit or intensive tar remover to soften the glue then just scrape it all off with another blade.
