first off remove the rear door cards,
then on the seat belt adjuster pop a small flat screw driver off to remove the small cap, then remove the adjuster button,
Then pop the top plastic above the seat belts(connect to the roof)
you need to remove the plastic that runs along the side, might need to remove seats,
Then you need a 18mm iirc socket to remove the bolts, or a Torx50 .
