Removing Front Side Strips
When removing the front sidestrips on a Mk2 Ph2, does the front bullet ala the "16V" "2.0 16V" part need to come off as well?
Ayet, just gave it a tug the now and it's all come off.
Bloody hard to shift the front ones though, no easier way then using a flat headed screw driver to prise them forward?
did you unscrew the screw on the inside of the door? they just slide off after you undo the screw no need to prising or breaking the clips!
Took the cap off the door then there was some clip that I couldn't move.
Used a screwdriver to lever the first one off but the other wouldn't come at all, is it meant to screw off?
mine had a screw then you just slide it off towards the back off the car but mines a phase 1. there is a guide on the guides section which is called spoiler and bump stip removal of something like that? have a look on there i think that is for a ph2! good luck
when i did it i took the cap off from inside the door, used a screw driver to push out the pin (which is below the first tab) then it popped out meaning it could be slid towards the back of the car
This is all I see when having the lug off!! No pin or screw, hard to lever off and yes those are my screwdriver marks :o
Took a bit of man power to remove mine, found it is best to get somebody to sit on the seat inside the car and hold the door steady, then it took me two people to slide it off!
