Removing original sidelight bulbs??
Car  Renault ClioSport 172
I can't seem to get the side light bulbs out of the holder to put new ones in . . :S it seems like if i pull on them too hard they will break but i dont want to break anythin !
does anyone know if there is a simpler way to remove them or is it just a case of pulling cos they do seem to be 'stuck' in ???
Spray a bit of wd40 in the gaps. Metal might have rusted abit.
Leave it for abit then wiggle them out.
i dont need any metal to come out if thats wat ur thinkin mate. . i just need to replace the bulbs or does any of the metal need to be removed too?? :S
No, lol.
The little metal pin connectors on the bulb, That make contact with the inside of the holder might have a bit of rust between.
he means the metal from the original bulb might be rusted to the holder a bit. the WD40 should loosen it
EDIT: beaten to it
No, lol.
aww right lol so a little wd40 in between the bulb to loosen it. . .wont it damage the connectors on the bulb at all ??
wont do nothing to the connectors. should clean up any corrosion a little bit and does not conduct electricity so all good.
