removing seats, temporarily
Car  CLK 55
hi i need to change 1 seat as it's worn out. is there any procedure as to avoid any airbag lights coming on? Also if that includes disconnecting the battery will my Ecu be ok as the car has been mapped. don't want it to lose it's new map.
cheers
The service manual says disconnect the battery for at least 20 minutes to eliminate the possibility of a bag going off. You won't loose your map.
Disconnect battery
Disconnect under seat wires
Remove seat
Re connect wires
Refit seat
Reconnect battery.
Will be fine and your map won't be affected.
