Removing stickiness from plastic panels
Louis
I Park Like a C**t
Did anyone find a good method of removing the stickiness from the plastic panels in the sports? I have fitted non sport door pulls/ hazard panel etc, however the satnav surround is all sticky and you can't just get a non sport variant of this.
I had thought maybe IPA, or wet and drying? Just want it to look half decent alongside the non sport panels.
TIA
mossyv6
  Trophy,V6,5GT,AG200
Can you not remove the sat nav surround from the top dash? Takes about ten minutes to remove the top dash.
It can be separated. It's plastic welded from behind. You'll need to whip the dash top though to do it.
I used ipa, soapy water, wire wool and some wet and dry, takes a while though.
