Removing Strut Top!!!!
mas
  MK7 GTD & Mini GP
argh... having lots of trouble removing the top of the strut in the bonnet area... got the allen key in there, goose neck spanner around the bolt, no matter how hard i turn it wont budge!!! any tips?!
rock solid, is it a two man job?!
:mad:
G_F
  BMW M3 & Williams 3
Its only torqued to bout 60Nm, so it shouldnt be too tight. Get some WD-40 on it.
Hold the allen key (hex keys with ratchet connection is better) still and turn the nut anti-clockwise
mas
  MK7 GTD & Mini GP
i have tried that :( soo fookin stiff, need a mate to hold it really.. is the nut on the top 21mm??
G_F
  BMW M3 & Williams 3
Yes mate 21mm, have you got a bit of tube to put over the spanner (make the handle longer) make it a bit easier.
  S2000
Get yourself an impact wrench. I bought one for £10 and it wipped the strut tops straight off. The other option is to take it to a garage and get them to airgun them off, then do them up loosely to get you home and then take it from there. Personally I would go with the impact wrench though as they can be had easily for £10 and if you are planning on doing this sort of stuff in the future it's well worth it.
