Renault 19 16v seats into a 1994 Clio RT?
  1994 MK1 1.4RT Clio
Hi Guys, is it difficult to fit the Renault 19 16v front and rear seats into a 1994 Clio 1.4 RT? If there is some work needed, what exactly do I need to do, modify rails??
:approve:
  1996 Valver
Re: Renault 19 16v setas into a 1994 Clio RT?
Fronts are a straight swap, Two 13mm nuts from uner the car and two large torx (T25/30??) bolts from in the car.
Rears are wider so will require cutting down to fit.
  1994 MK1 1.4RT Clio
Thanks for the replys guys.
Do the fronts fit on the Ren19 rails or do I need to change them onto clio rails?
Also with regards the rears how hard is it to cut them down? What exactly do you need to do?
