Renault Clio 1.4RT - Injection system
Car  Clio Mk1
will the clio 1.4 rt injection system be the same as the clio 1.2 unjection system or different ?
I'm not certain but I'm pretty sure it will be identical.
The 1.4 energy engine is only an enlarged version of the 1.2 energy engine.
I would imagine it would be the same if they are both energy engines (up to N-reg iirc). There were two different setups on inlet/injection though i believe (both were used on the 1.2 and 1.4 pretty much at random iirc) but I'm not sure if they are interchangable or if the loom is the same for both.
Why do you need to know?
just wondered if it was different would it make my 1.2 a bit faster just thought it would be bigger thand the std 1.2
