I've just replaced my radiator and flushed the engine with a hose and then two flushes of water, running it to temp inbetween to circulate with the thermostat open, so I'm fairly happy that its now just plain water in the system.
Now I need to put coolant in. Because I wont get all the water out it needs to be concentrate so that I can drop the lower radiator hose off, let the water out, and add about 3.5l of concentrate. The renault coolant I've seen has all been premix, can you get concentrate?
The conventional advice was "just use the genuine Type-D coolant", but RPD suggest it's being discontinued: https://renaultpartsdirect.co.uk/parts/service-parts/dacia-renault-engine-coolant/ as does this thread: https://cliosport.net/threads/glace...-mistake-or-genuinely-the-right-stuff.848818/
I don't want to fill my freshly flushes system with coolant i'll no longer be able to buy.
I don't really fancy the new RX ‘Type E’ Alliance coolant (blue) as it's ripe for getting topped up with standard blue by accident
So that leaves the compatible RX ‘Type D’ (New version-Yellow)? Or something aftermarket and compatible with a colour that avoids future contamination.
What have other people gone for?
