Replacing Airbag Unit
Car  182
I've had a search and I know HOW to do it, but not what happens WHEN its been replaced.
So: If you replace the airbag unit with a different one, will it work or does stuff have to be reprogrammed?
Cheers peeps
Can anyone else confirm this? If it is correct, how much does it cost to reprogramme? (I already have the unit)
it needs a voltage drop test doin, has to be no voltage at all in the signal wire to the unit.... never heard of them being 'programmed'...... were did ya get ya info from edde?? just i worked in nissan on the final line and repaired the test leads for the air bag testing unit....
Autodata
Cannot be bothered with looking in dialogues but I'm sure they do mine did when i had mine set off.
Just for future reference, I disconeccted the battery, replaced the airbag unit, connected battery up again and the airbag light DID NOT stay on! It all worked fine, straight swap, no reprogramming needed.
Yay!
