replacing brakes on warrenty
  liquidized RacingBlue 182
i have just went over 13k miles on my 182, i dont feel like the breaks are even near 100% wood i get them replaced on warrenty? or how long shood they last before me having toi change them my self? thanks!
Nez
  White Megane R26 F1 230
Sure they don't just need a bleed? Having mine done at the 12k service.
  182cup/D40/Hornet
mine don't feel as good as they used to at 12k,so I think a order for pads/fluid from fred will be on the cards in the new year ;)
Nez
Air gets into the fluid.. they run new fluid through this system to get rid of the air (i think)
Mine are really bad... did a brake test the other day.. 80-0 my foot was flat to the floor and they just went flat.. no stopping power.
  182cup/D40/Hornet
Pads&fluid I would go for,about £100 for what I'm after,depends what you want,changing pads over easy enough depending what your like with spanners of course
Nez
I would get them checked. I really hammer mine and there is loads left on the pads, they just need a bleed.
Maz
  LY 200
Mine are fine at 30k, you lot must be mean to your brakes ;) lol
have to be mean with my icle breaks having no speed limits lol
gonna have to get them checked and make sure its not just me been paranoid!
I have done 2 track days on mine too .. pmsl
Yep best to get them checked .. they do it as part of the 12k service anyway .. have you had this done yet ??
  Lionel Richie
Maz have you ACTUALLY checked the brakes, or are you just going off what Renault have told you
one of our customers destroyed the std brakes after only 5K
  182cup/D40/Hornet
mine haven't felt to good for about 4k,still stop me,but just seem to have lost their 'bite' and once the're hot not to good.
Maz
  LY 200
Yep had them checked by Renault and Tweeks.. backs are ready for replacing soon :D
Thinking about trying them Mintex ones .. anyone know what they are like ??
lol, i mean i have no speed limits on the normal roads! i lve on the isle of man, so always drive fast
There not very think as stock anyway least there only cheap though. (so long as you on't neeed pads) ds2500's you can get in rears if you want.
^^ huh ??
Oops err my typing getting worse.
Meant to say the pads arn't thick as new so even 2mm is still a good protortion of the pads. Least there only cheap to change anyway. You can get DS2500s if you want to on the back for a few quid more.
Maz
  LY 200
I know they all do but some more than others right ??
I want something that don't squeal (sp) and give off as little dust as possible..
  172CUP/Fiesta supersport
my cup has just turned 3 years old and is on 15K and a wee bit, I replaced the front discs and pads around 13.5k, a few weeks ago with the MOT looming I realised I was gonna need rear discs due to corrosion (cup problem) and I rang renault uk and argued the case. I managed to get rear discs and pads fitted at the local dealers and renault paid 70% which worked out far cheaper than actually doing the job myself.......so it may be worth a ring to reanault uk, although you would need to find the problem you have because if it's just worn pads you can forget it!! but if it's corrosion you may have a case as I managed it.....HTH
  54 astravan 1.7tdci
i wish people could spell it's brake. B-R-A-K-E.
MRBILLYUK
  FF Jeden Osiem Dwa
^^^ Its even worse when they say they've just " brought some new breaks " , lol ;)
  clio 172 cup
ive got ds2500 and they are good but a fair bit of dust. i used to have green stuff and i thought they was almost as good as the ds2500 and no where near as much dust
