replacing rear discs (abs)
Car  clio 172 sport
just wondered when i replace my rear discs would it be advisable to fit rear dics with the bearings and stuff for the abs are will i be ok to just replace the disc?
The bearing are pressed into the disk, IMO it's easier to buy new disks with bearing already pressed in. Otherwise have to remove old ones and then press them into the new disk (need a special press)
you can swap the ABS rings over easy.
bearings are £20 per side and about £10 to be pushed in at a garage
