Renault Clio 172
				Hi All,
I've got a Clio 172, 02 reg with 65k on the clock.
I've noticed something, but Im not sure if it is a fault or not.
The little green light that comes on to tell you when to change gear so you do not damaged the engine. Well sometimes it comes on at around 6,000rpm, others at nearly 7,000 rpm. Any idea's why it comes on at different times?
I presumed it would be set at a set rev limit. Or do other factors such as engine temp, etc, come into it?
Cheers.
Dan.
Cheers.
Dan.
