Rev - Wireless iPhone OBD reader!
Car  133, 182, Kangoo 182
Just seen the "lite" version in the App store and decided to take a look at it.
Providing the hardware and app aren't too pricey this would be awesome!
http://devtoaster.com/products/rev/index.html
Rev Features
Built-in Metrics (No special hardware required)
  • Lateral and Forward Acceleration: Graph your cornering, braking and acceleration G-forces. (Available in Rev Lite)
  • GPS Track: Visual track displays your location and acceleration data - see how you are braking and accelerating around corners. (Available in Rev Lite)
OBD Metrics (Requires OBD-II/WLAN interface hardware)
  • Vehicle Speed
  • RPM
  • Fuel Consumption
  • Engine Coolant Temp
  • Fuel Pressure
  • Calculated Engine Load
  • Throttle Position
  • Intake Manifold Pressure
  • Air Intake Temp
  • Timing Advance
  • Mass Air Flow
  • Fuel Level
  • Barometric Pressure
  • EVAP System Vapor Pressure
  • Fuel Trim
Visual Representations
  • Gauge: Displays a moving needle and LED display to show current reading
  • Graph: Displays current value over time
Engine Code Retrieve and Reset
Want to know why your Check Engine light is on? Rev will tell you why!
  • Engine code checking
  • Listing of all engine codes thrown by the vehicle
  • One-button reset of your codes and Check Engine light
Auto-centric User Experience
Rev has been designed to be easy to use in car-mounted iPhone/iPod Touch installations.
While we OFFICIALLY DO NOT RECOMMEND USING Rev OR OTHER IPHONE/IPOD TOUCH APPLICATIONS WHILE DRIVING, we do think it would be a mind-bendingly awesome experience were anyone to actually try it.
  • Quick taps for bumpy rides - double tap gauge to zoom in/out, swipe to graph view
  • Car-mount-friendly orientations - landscape or portrait
  • Dark background color scheme - easy on the eyes, day and night
Wireless Freedom
Simply connect to the OBD-II/WLAN device by approaching your car. While connected, your iPhone can still access the Internet via EDGE or 3G.
They have now released the hardware and the full app is awaiting approval.
App: $50
Hardware: $230
Maybe not then...
