Rivet tool for fitting fabia vrs splitter
Purely because of some peoples input about them in other threads
Plus I'd of thought the rivets would be more secure.
If self tappers is a better idea then I'll do that?
Mines been on with self tappers for ages and it hasn't moved one bit :)
And I assume you cut any excess after its on?
I just thought rivets would mean that no drills would be needed
if you was to rivet it on and you needed to remove the splitter it would be a nightmare getting the rivets out
self tappers no need to drill pilot holes thats why they are called self tappers hence the little drill type bit on the end;)
Wouldn't be a nightmare getting the rivets out you can just drill them out with a pilot bit. Better using self tappers though as they are easier to put in and just as solid as rivets if you screw enough in.
Self tappers are more than enough, i parked over a kerb yesterday and when i reversed it damn near pulled the whole bumper off and the splitter didnt budge!!
