Ronals turbos for my clio
they should be fine my oz wheels are 4x100 and et 37 they are 16 inch as wheel so should not be a problem
they'll fit, but you'll need some spigots which isnt an issue, and while your at it i'd go with spacers to properly fill the arches
But dont let that put u off, spiggot rings were £10 when i got mine. Those wheels should fit fine.
well 37 would fit nicely, but thats not really the euro spirit is it. i actually ordered some ronal turbos for my 1.2, and ordered them on a 37offset to give me flexibility with the coilovers and clearance. was planning on 5-8mm spacers on the back, and then at least 10mm on the fronts. so i would imagine 8mm rear, and 10mm front would do nicely.
like middo said it depends on how low you go, ive got turbines on my car with no spacers(not sure on offset) but lowered about 60mm and the rear arches are just over the tyres, so if i did put spacers on the they would rub, but i think they are 40somethign offset...
im planning to lower minimum 60mm, i want it to look low and wide and if it is possible the wheels stick out the arches like on the old minis with the 13x7 superlights :D
i think 60mm might be your limit mate, but will look so good, before i bought my turbines i was considering turbos, but alwaysd thought they were really expensive for some reaosn, but even brand new i could get them for £60 a wheel 15 x 7!
get them, will look so good when the car is lowered...
