E39 M5 & Corsa track
According to that graph you've lost nearly 50PS i.e. 25% through the drivetrain. I'm sorry but thats just not possible. Based on your wheel figure of circa 152.5PS an approximate fly figure based on a 17% loss is 178.4bhp.
If anything I'd say that was low and you really should be seeing 181 - 186 bhp depending on how 'strong' your engine is.
Try a different rolling road!
M
depends what rollind road it was done on, on a maha rolling road such as our transmission losses are calculated on the run down, where as a dyno dynamics "guesses" the transmission losses.
so for example the graph with high transmission losses which you say isn't possible, if it was on a maha rolling road the low wheel figure could be explained by a sticking brake caliper, then the high losses would be seen on the run down giving an acurate flywheel figure, where as a dyno dynamics wouldnt see this and would give an inaccurate flywheel figure.
also things to note with flywheel calculated figures, we have done alot of testing a few years back to quieten down some forum talk of rolling road being more accurate than others.....
we tested wheel figures with no glue on the rollers, then put spray glue on the rollers, the wheel figures changed by 6bhp, the calculated flywheel figure on a maha rolling road saw 0.5bhp difference accross the run this was down to the fact that the maha dyno will work out the transmission losses.
were not saying that the dyno dynamics are a poor inaccurate rolling road because they arn't they are a well prices rolling road that works well.
