RS 232 D connectors
Gaz_
  Extreme mode
Where can I get a 25 pin D female plug that I can wire/solder myself?
Need to make a lead for a udl of alarm panels. Tried egay and the like, but can only find converters and the like?
Share the wisdom
  A.N. Other
25way D-type (DSUB) are what you're after. Maplins sell them - not the cheapest place but easy, and they do backshells too.
Gaz_
  Extreme mode
Cheers i'll search that, if not i'll nip down
I do have an old lead off a US robotics Modem, but having to run it through a gender bender, and I cant get it to work. I need 02 (TxD),03 (RxD),04 (RTS),05 (CTS),07 (GDN) which bell out correctly at each end, and are a common connection. These the only connections I need however, I'm not sure what else is connected in it, I presume this might cause some conflict of why I cant connect??
Ah, so i buy this,
http://www.maplin.co.uk/25-way-d-sub-hood-withthumbscrews-1124
and then a hood to cover it?
Here's me thinking I could buy the lot as a kit!
JohnnyE
  ITB'd Clio
Just checked for you bud i thought i had one i will check the van tomorrow .
I used to have loads as we used DM dvr's and there was always one in a spares pack they gave you....................
Gaz_
  Extreme mode
DM proper kit...!
Cool, need to connect up to a Galaxy RS232 Module ;)
