RS2 Inlet Ebay?
Drakec
Trader Rating - 0%
0   0   0
  Bmw m635csi,polo.
Ok i have ordered one of these now going to get my car on the rollers down at rs before i put it on to get before and after figures. My car is standard apart from a ktec exhaust and sports cat so it will be intresting to see what gains i get.
ADS_V6
Trader Rating - 100%
11   0   0
  172 cup clio v6 st
cant wait for the results,if good owner can expect an order from me :smile:
2   0   0
  clio rs 2000
here is a performance anlyzer with rs tuner we made last night
the car is ph1 clio 172 with 63mm exhaust system and a fastchip ordinary map with 2 person
but the car has 195 45 15 tyres so you have to decrease the value %5-7
in my calculation it gives over 205 hp
ADS_V6
11   0   0
  172 cup clio v6 st
hi how long does it take to fit the manifold as wont be doing it myself
BashRacing
2   0   0
1-2 hours, any longer would be taking the piss, is there any members local to you to give you a hand as it's not particularly hard.
ADS_V6
11   0   0
  172 cup clio v6 st
thanks i was reading a post on the original rs2 and it said 5 hours,so just thought thats a lot of labour,thanks again.
2   0   0
  clio rs 2000
if you are able to use tools you can take off your oem manifolds in half an hour and fit this in 1.5 -2 hours
the most difficult thing is the 3 bolts under the intake which is attacehed to the head
you can turn them by hand till the end and then tighten them with 6 allen key this is the easiest way
ADS_V6
11   0   0
  172 cup clio v6 st
Hi could you get a video up of the sound of this when driving if possible?
Trader Rating - 0%
0   0   0
  Cayman S, RB 182
@cliosportap
How would you see your inlet working with a set of cat cam 438?
Does AC need to be removed to fit this?
Any modification of the slam panel etc to fit?
2   0   0
  clio rs 2000
You dont need to remove ac. Also no need a modification to slam panel
The yellow car is newly rebuilt and we are not still giving full throttle . It has 433 cams and the response is very good. After the final map for the ms3 ecu we will start to ride it asnormal
The only thing you haveto remove is the bracket which is attached block to alternater. We always remove it but didnt try if it is still can stay there because while fitting the inlet it makes problem for using tool
ADS_V6
11   0   0
  172 cup clio v6 st
I will be ordering one of these next week.My cup already has the 98 ron remap on standard ecu,so not expecting a huge difference but i dont fancy turbo or itbs so this my only option thanks
ADS_V6
11   0   0
  172 cup clio v6 st
cant wait for mine im keeping the ktec filter off my induction kit,cant get rid of that noise.
ADS_V6
11   0   0
  172 cup clio v6 st
Hi iam trying to sort best way of fitting this,as i have the rstuner locked to ecu,so might be swap ecu and another remap i think
Trader Rating - 0%
0   0   0
  clio 172
I have a ecu uch set up I bought a few months ago off ebay never fitted it couldn't be arsed .
If your after a set up and they match
ADS_V6
11   0   0
  172 cup clio v6 st
thanks its got to be a cup one,i think they are different to normal ones.Cant wait to get this manifold on.
ADS_V6
11   0   0
  172 cup clio v6 st
fitted in about two weeks as turkey its coming from,then got to sort the mapping out as its a 4hour drive.So for a week or two it will be on the rstuner 98 map.
