Rs200 window seal rubber replacement.
Car  Rs 200
hi, all
I collected my window rubber seals today from Ren in Colchester and to get them fitted. However there team said they can't fit the seals due to the rear windows are bonded, and there don't have the equipment to install them.
How easy are these to fit as even they said there a common fault.
Any guides or recommendations.
If it's the seals I think, the old ones just pop out, clean the excess adhesive off, and fit the new ones.
If you're still stuck after I've finished work, I'll get you the guide.
You'd have to be a paid up member to be able to view it mind
@Sunglasses_Ron @Pacman.
Are we allowed to pinch 197.nets guides since they're our subsidiary now?
As above, they are just stuck to the glass. You can pull the old one off, then clean up the excess/residue. This is the important bit - it must be fully clean otherwise the new ones won't stick.
The new seals just stick into place along the edge of the glass. No glass removal is needed.
Hi all changed over the seals very easy to do. as others said only time consuming part is the removal of old glue
Pad.
