RSI engine into an RT
  K20 eg 217 whp.
Dont know if this has been done as i have never seen it.
Would it be an easy change or would it require as much work to swap as the valvaer engine??
Thanks , JB
  S2000
pretty straightforward tbh. You can re-use the driveshafts, gearbox,dogbone engine mount, gearbox engine mount and a few other things. I'm not sure about the drivers side engine mount, think it may be different on the RSi. Go and have a look over on retro-renault and do a search in the archive bit as I was looking into this last year at one point and theres a thread over in retro which will tell you everything you need to know.
