RStuner or RStuner Pro?
Car  BMW M135i
Any benefit to getting the pro kit over the normal one barring the wide band lambda input?
I'll never be using a wideband lambda as far as I can see and every other feature seems to be there in the standard one.
Looking at ordering one but wanted to make my mind up whether the pro is worth the extra 20 sheets?
The only difference with the pro is the wideband input.
Go for the normal one, I'm more than happy with mine!
Wideband is of course the only additional part but the main advantage is that Henk will write up a cal file for you starting from scratch. So you gonna get probably the most out of your car. This is gonna be very good esp for heavily loaded cars such as running on cams.
For more info --- info@fastchip.nl
