Running 172 alloys with FK Highsports.
Car  TT 225
Just wondering if anyone is running these with these? I heard someone say you will need spacers on front and rear? Non-sports btw.
Adam
I am, have 15mm all round. You will defo need them on the front (5mm should see you right). Rear isn't needed but can be done. Sometimes if you go too low then it will rub. Personally, to be safe I'd go 5mm all round.
I've got KonigSports and I needed spacers to run a little bit of negative camber on the front.
