Running a cable from engine bay to inside of the car?
Munday
Car  RB 182, 1275GT, C220
Hi,
I have a 2005 182 Cup and would like to run a cable from the engine bay into the car so I can operate a switch.
Are there any pre-drilled holes or will I have to take the dash off? :(
Thanks in advance!
There should be a gromet passenger side footwell, under the carpety stuff. Quite hard to get to from the inside, but easy enough from the engine bay.
Cool cheers mate.
I might make use of that then. I don't want to go hacking the car about but that should do the trick.
whats is for mate? if its just a simple low current 12v then you can branch of something for the power. rather than battery , but if its for an amp or something heavy duty then battery for sure :)
Bonnet release cable grommet chap, peice of piss to get at and push a cable through. My amp cable is through it, no drilling, no leakage or chafing and it took 5 minutes to feed it through in the dark/pissing rain with no torch, lol.
Hi,
Thanks in advance!
Should of asked yesterday and I would of shown you.
