Id keep it tbh, no real disadvantage to it and the clio system is quite good.
could u not pull out the abs fuse or relay to deactivate it?
If you want 50/50 braking you can, but have fun having the rear of your car overtaking the front!
all the compensator are pre set all valves in the abs pump are open. only time they are working is when the abs is in use and the valves open/close to hold or reduce pressure in each brake to stop the wheel locking out.
