Running fault - mini
  RRS, 172, ST3, VTS
Hi
I've a 2007 mini one which is running of a cylinder. I have tried a new coil and changed spark plug but it's still no better. It's off cylinder one and the EML light is on. I have plugged it into diagnostics and the fault code is only showing that it's Mis firing on cylinder one. I also deactived on the diagnostics the injector on cylinder one which made no noticeable difference to the way the car was running which makes me feel it is an injector. The car will run a lot better and on all four cylinder when it is higher up the rev range but runs poor and beings EML light when idleing. Any suggestions welcome!
