Yep its either on or off.Quote: Originally posted by qwerty on 20 July 2004
edde, fair enough but we agree that VVT is either on or off (ie its not variable or multi stage).
But you say its switched on above 1800 rpm if water above 80 and manifold pressure is over 800mbar?
So if a 182 is driven with the VVT disconnected, you say it will still have a power surge at 5,000 rpm?
Does any 182 owner feel like performing the experiment?
I cannot see any owner doing it as youll probably have probelsm when the ECU find out the VVT isnt activating.
But yes if your coolent temp is below 80 degrees and you rev you will get the kick.
