S21 screen protector!?? Advice required?
davo172
  TCR'd 172
Want a tempered glass screen protector for S21 samsung that still works well with the fingerprint sensor? According to reviews most don't.
If not tempered glass what are you using that does work?
Any decent case recommendations also?
What have you got? Talk to me!!?
dann2707
On my curved screen s20 I tried one that was meant to work with the fingerprint scanner. Fitted it and it was s**t.
I bought a Whitestone I think it's called one where you uv light it onto the phone. That started to peel so I sacked it off.
In the end I ran without and cracked my screen 2 weeks later
Flat Eric
Sing Hosanna!!
  F31 35d, Berlingo Na
I just use the one that came on the phone from factory. It seems to do the job
  focus st3
I bought an otter box case and screen protector for my s21 ultra and that seems to work ok?
MLB
I've had tech21 Evo Check cases for both my S7 and now my S20, they are grippy and have good impact protection with a slight lip top and bottom so you can put the phone down with the screen facing down.
Screen protector wise it's just poor, no tempered glass options that work with the finger print scanner so resorting to JETech TPU film ones.
I'm on my 4th in a year, they mark from swiping over time and they rip easily and when it's hot they move and peel. Cheap and easy to reapply though.
I'm seriously considering moving away from Samsung for this.
Sash
  A Yellow One
I’ve always used Zagg products. Never had an issue with iPhones but can’t comment on Samsung’s
https://www.zagg.com they’re not the cheapest but they have always been good to me.
Gally
Zagg are good like Sash said. Samsung's own are very good. Look at Spigen also.
Most should work. Always re register the finger print afterwards and you can sometimes change the sensitivity if you're wearing gloves etc this helps with screen protectors.
