When you say faulty... What is wrong with it? Normally if you have a damaged / down injector the car will go into limp mode and be pretty much undrivable.
The diag machine said open circuit cylinder 4 injection valve . Mines not gone into limp mode or anything jus runs a little more lumpy and use alot more fuel .
If its using a lot more fuel the injector could be dribbling which can wash the oil from the cylinder and you can end up with a lot of damage to that cylinder
