Scratch removal question..
Car  Storm Grey 200
If i fill a deep scratch in with a top up pen and then wet flat it down with say, 1200 grade paper? Will i be able to buff it back up to a proper shine by hand, using scratch x?
I would use a finer grade of paper, but using some elbow grease you will remove the sanding marks if you use 2000 or 2500 paper.
nick-89 i have some 3000 grit i can send you a sheet if you like . You can use Langka blob eliminator have a look on www.frost.co.uk . i have used it with great results .
ah right, yea i thought it might have been a bit harsh, hence me asking the gurus. :) i've got loads of wet and dry so i'll just try it with 2500/3000 and get the scratch X on the go. It was nice knowing you, arms ;)
