Seat belt buzzer no longer sounds and light on dash not displaying help please
Car  Clio
Hi all, when I get in the car and start it once I pull away the seat belt buzzer goes off and dash light flashes, went out today and nothing. Car is running fine, no air bag lights up on dash, can anyone tell the problem or a way to diagnose if there is a fault. The 2 wire plugs under the seat are all connected and ok. Many thanks Ross
If you take apart your seatbelt (where the clip sits in, torx IIRC) you will should see two pins that get pushed apart when the seatbelt is connected and vise versa, may just need a clean up, or pushed back together to make the connection. Hope that helps and makes sence!!
