Seatbelt pretensioner mount
Car  RB 182 FF
I've recently bought Sparco R100 seats and OMP subframes, and was wondering how people mount the seatbelt pretensioner to the subframe. To confirm, my seats are mounted on rails and will need to slide forwards and back.
I came across this old thread http://www.cliosport.net/threads/mounting-pretensioner-to-subframe-soloution.741265/ which sells a part that looks perfect.
Anyone know where I can get this, or something similar?
EDIT: Has anyone ever tried fitting a set of these to the edge of the subframe to just mount the pretensioner to? http://www.sportseats4u.co.uk/omp-low-profile-steel-side-mounts/prod_902.html
Did you sort it ?
Hi sam55,
Sorry to bother you.
Was just reading your post regarding fitting Sparco R100 seats and OMP subframes to your Clio dated may2015. I have exactly the same scenario with my sons car at the moment. Did you manage to fit them ok and how did you get around the pretensioners.
Hope you don’t mind me asking.
Thanks.
Hi sam55,
Thanks.
I managed to source an L-shaped piece of metal on eBay, which enabled me to bolt it through the subframe and then mount the pretensioner to it. This is the part here: https://www.ebay.co.uk/itm/Seatbelt...c-Car-7-16th-Bolts-Washers-Nuts-/292018623843
Hope that helps!
