Seatbelts not pulling out
Car  330i, Alfa 147 & SP1
I bought a full set of seatbelts from a trader on here (awaiting reply still) on 1st inspection I can't pull any of them out. It's like when you pull them to hard they click and stop.
Just wondering of once in car and earthed out or whatever they allow you to pull them out or have I been sold a duff set from a smashed car?
Haven't bothered stripping car down to fit in case it's a waste of time.
Have you bolted them in ?
You wont be able to pull them out until there at the right angle
The trader would be able to tell if they have been set-off as they pull really hard and are just easier to cut.
Sounds about right. Didn't want to start stripping it to fit them that's all
Looks like I'll be fitting them, pulling them out and cleaning them as they're fecking minging
You can pull them out as I fitted some the other day for a customer
put it on a flat table on the side. (try both sides) one side should be the right angle to let it pull out
Thanks rob. Rear ones came out nicely but no luck on the front but they definitely need to be spot on angle wise so I'll just do it in car I think. Fingers crossed the fronts will work
