Second monitor, no signal
  MK4 Anni & MK5 Edt30
Alright folks, looking for a bit of help here if possible.
Basically, I've just moved house and set my PC back up. I always use 2 monitors using both DVI outputs on the back of my ATI card. It's not the best card in the world but it does the trick, it's a HD5750.
My monitors worked flawlessly at my old house but now the 2nd monitor doesn't seam to work. Basically just says "no signal." I've swapped all the DVI cables around and the 2nd monitor works fine when it's plugged into the main output on it's own. It's definitely plugged in correctly and I have downloaded to latest drivers. When I look into my card properties I can click "detect monitors" and it doesn't pick it up but still states there's a second output on the card. Any ideas or do you reckon my card has given up?
Much appreciated :cool:
