Seriously considering this but need abit of info!
you'd need a few bits as yours is a ph2. You dont have a throttle cable, so you'd need that and a different pedal.
you may also need a bracket for your coil, although Laine is selling everything so ask him about that. Also you'll ideally need a new 3 wire lambda sensor (use one from a mk1 clio 16v)
Thanks Danny, not too much needed then so shouldn't cost too much extra! How much would you guess fitting would be? Saying I paid £1300 for the kit, Could it be fitted for less than 700ish?
Thanks again danny! one last question to anyone really....how much does mpg fall on average with ITB's? The other kit I'm considering is the RS2 which maintains more or less the mpg I get now! If mpg seriously falls may count against it
