Setting a WPA or network password?
Car  Punto/Clio GTT
running a netgear router with blueyonder. using a network card via usb. connected to the internet ok but it isnt protected.
when i click on the netgear software it says "security, disable/enable" WEP, create with passphrase or enter key automatically. but when i try enter something in, it just disconnects the broadband and wont connect until ive disabled it again.
ideas?
i've got the same problem with a siemens router I set up as part of a tiscali package I set up for a friend. Won't stay connected unless I turn off the security which isn't ideal. Don't know what's wrong.
http://192.168.0.1
username : admin
Password : password
Go to the Wireless settings Enable WEP then enter a passphrase or set the key manually, Don't forget to hit apply. Once you've done this set the Key on your Computer
Yes it's very easy to set one on the router, very easy to tell windows or whatever what the password is...
But for some reason the siemens router and guessing FM's, it just keeps dropping the connection.
Cheers anyway.
