So got hold of a second hand set of ASTs and want them set up best I can for track. I'll be getting the car corner weighted eventually once I've finished weight reduction.
So much contradictory advice online, some say use the wheel centre to arch, whereas others say this is a no no and it should be done via measuring the strut height, and this should be done before fitting, which I really don't get as you have no reference of the height and would need adjusting on car anyway.
What I plan on doing is setting the height half way down the struts off the car then fitting, adjusting accordingly. The issue I'm having is even with my weight ballast in the drivers seat, when setting the height I don't think an exact ride height for front and rear axels will be correct. Obviously the rear will be a tad higher for the forward rake but I'm thinking the osf will need to be a tad higher than the nsf to add more weight to the nsf to balance the front axel weight? What confuses me is in changing a front corner, that will then alter the rear directionally, so lowering the nsf with raise the osr.
Once set I'll be having it aligned for camber and toe but don't want to get on track and it handle like s**t, therefore needing to adjust the ride height, in turn changing the camber and toe settings, making it all pointless, lol.
Or am I just thinking to much into it, and it's pointless without properly corner weighting it?
