sex piss
Finally after several sets of suspension on my 182 i've now got a set of H&R (only just released a kit for 182s) coilovers sat under the arches of the french shed. I'm just off to clean the spunk out of my drawers, if you want to drop your 182 on quality kit get the H&R's you wont look back :D
Damn i was looking forward to seeing some spunk pics ;)
Glad you've finally found a decent kit for it though mate!
How much of an improvement over standard is it?
BenR said:
Remember when i called you on the motorway
  Seat Leon Cupra 290
how long does it take to fit them as i am looking at getting a set of these, does it scrape the arches at all under heavy loads or anything? whats the ride like under normal road conditions?
fitting depends really, couple of hours-ish. If its the 1st time you've fitted them you might want to put aside a whole morning and part of the afternoon to be safe. The front is the only place you'll have issues with fouling (assuming you have standard wheels on) and thats only part of the arch liner and bumper bracket which can be trimmed/bent to solve it. But depending on the height you set it at you may not have any issues. Ride is perfect, infact IMO better than OE.
  Seat Leon Cupra 290
never owning coilovers myself, how often do you adjust the height does it take ages/difficult to do? sounds good best place to get them from?
tbh unless you have any reason to adjust them (example you have a driveway that needs clearance but you also do track days so high day to day and drop for the track) You may as well set at one height ant leave them. Have a look around as the price can vary alot depending on where you are looking.
Been too lazy, plus i will be adjusting the height again once the springs have settled.
I bought direct from the distributor because we've got an account with them at work, saved myself £££s :D
