Shagged dogbone/gear selection - related?
Poopensharten
  Golf R
Hi guys, quick one.
Can a shagged dogbone cause gear selection grief? (i mean very slightly not as in being impossible to select?)
Just wondering before i change it next week :)
  172 Race Car
Yes very much so. the gear linkage is a solid rod, if the dog bone is shagged the engine will move forwards and backwards
Poopensharten
  Golf R
Another quick one, the bushes for the dogbone, are they easily removed or do you need a press/vice?
Dr HMS Derv Destroyer
  MK1DTi/vivaro/corsa
Should just come out if they're shagged tbh.
Mine gave up and made the engine bounce rediculas.
Managed to take the bushes out of mine with a socket and hammer ( big side ) other side just fell out
Poopensharten
  Golf R
The one under the battery dan?
Battery out, the tray underneath, is it held on with bolts or torx screws or what?
Poopensharten
  Golf R
Roger that Chip, its not doing that, just the banging off the sub frame at high rpm.
I'm going to have a wee look at the mounts today as i haven't had the time so far!
  330i. E30 Touring.
Inspect all mounts visually. Top two, grab the upper inlet and rock the engine- see how much play there is.
Loosen upper engine mount, pull engine forwards, tighten mount.
Poopensharten
  Golf R
Briefly done this a few weeks back mate, it hardly moved even after loostening the four bolts on the top one, it looks/feels solid enough!?
