Just fitted 82mm on fronts and heads sticking out about 20mm so centre caps wont fit.
I was looking at 10 or 15mm spacers, might also be an excuse to get some new wheelsAh I see, your running standard wheels.
Spacers will sort that out, or shorter studs.
Yeh the bolts bolt it to the spacer so std size all around. 68mm it is cheeraHub spacers won't make a difference as it goes into the disc, therefore 68mm would be perfect.
Measure one of your wheel bolts. It should be around 60mm iirc.
Is your spacers, bolt to hub and using existing bolts using longer bolt type?
If your your using existing wheel bolts measure around 60mm I'd get 68mm. If you have longer bolts then I would add the difference from 68mm plus your spacer size = stud length.
I run 82mm on the fronts with a 16mm spacers. Pics on the previous page.
I've got the A I Tech competition studs and the copper coated wheel nuts.
Not cheap either, but didn't want to break any more after I had a couple fail.
Bimmec, personally couldn't see an difference between them or the PMS. Only the A1T studs look to be significantly different/better quality.From PMS or ebay/Bimmec?
That's my plan James. I have the Loctite 270 here, studs, nuts and spacers arriving this week so will try and do them Friday afterwork and leave overnight. (I know its 4 hours, but this easier for me)
I've got thread cleaning tools (in m12 x 1.5) so I'll do that and blow out all old crap before I fit new. Did I read that you fit the new studs only to 25nm once they are home?
I'll be honest I never know how tight the actual wheel nuts need to be.
Think I set torque wrench at 110.
So have we worked out which stud and nut kit is the best then?
Anybody use different wheel nuts other than the ones of Bimmec, PMS, etc?
I'd quite like some that are like these.
I had some D1 ones years ago on my old 182. These was 40mm and perfect size, but aluminium. Not sure if that's recommended though? Worried the material will be weaker than steel?
View attachment 1452987View attachment 1452988
To be honest Mark. Those lotus ones are cheap for Titanium. The ACER sets are around £400 a set.@frayz that's what i thought. Titanium ones are lovely, but big bucks though.
I'd like the lotus ones but not at that price. Sure I've seen open ended steel ones before in similar style to those, but cant find them now.
I did find a full titanium kit, but resisted as i knew you would make fun of me![]()
@a17vtsYou can get these in your chosen length if you want.
LOTUS ELISE EXIGE BLACK TITANIUM LONG WHEEL LUG NUTS STUDS RACE TRACK SET 32 PCS | eBay
Find many great new & used options and get the best deals for LOTUS ELISE EXIGE BLACK TITANIUM LONG WHEEL LUG NUTS STUDS RACE TRACK SET 32 PCS at the best online prices at eBay! Free delivery for many products.rover.ebay.com
Wouldn't use titanium tbh.
It only has the tensile strength of grade 8 steel, whereas PMS and BIMMEC studs are 10.9 or even 12.9
