Clio 1.4 16V (2004)
Hey guys, was just wondering if anyone could possibly help me with a problem I'm having with my clio (2004 Clio 1.4 16V Dynamique):
When I brake, the side lights come on and when I turn the side lights on the brake lights come on too.
I've done a fair bit of googling on this and what most people tend to be saying is that it'll be a rear earth connection? I've had both lights off, checked the twin filament bulbs for a short and checked all the connections and rear earth points for corrosion but they were all flawless? Almost as if they're brand new.
I've had each brake bulb out and had a mate press the brake pedal and the side lights still come on, does that rule out the bulbs then?
I'm also wondering if maybe a passengers kicked something loose under the glove box or whether there's an earth under the bonnet I need to check?
The only work I've had done since buying the car about 6 months ago is replacing the heater fan and that was done about 3 months ago so surely it cant be that?
Hoping for a cheap fix! Cheers
