Side lights/ parking lights help please
  Renault clio
Hi All,
First post , Help needed please
Just bought a 2012 Clio which has failed its test due to lights.
The problem is when you turn on the side light / parking lights, the side lights come on along with the head lights on the first turn of the switch. The second turn does nothing as both sets of lights are already on.
Full beam works as normal
fuses are good
bulbs are good
I've replaced the switch / indicator stick but no difference. still the same problem.
Haven't check relay yet and advice would be great as want to get it retested ASAP.
Andy
  Clio 2 ph 2 1.4 16v
Maybe you have headlights on option , on old clios you can flip the switch twice in a rapid succession and it activates or disables this option , if im wrong and anyone knows anything else pls do tell .
